Page 3 of 3 FirstFirst 123
Results 51 to 53 of 53
Thread: New to mightyram50, not to Mitsubishi...
  1. #51
    At this point I've only installed the headlight harness (the rest of the relays are only dummied in there) I've split the harness for the A/C from the truck, chucked the old relays that were fitted to it and wired up the new relays that came with the relay block and mimicked the wiring pattern for the A/C fan and compressor layout. I didn't like the way the top cover was designed to sit on the block so I trimmed one locator tab and rotated the top cover so the bevelled edge faced into the engine bay instead. There is still a ton of wiring to do - I'm replacing all of the harness sockets (they've turned to chalk and the terminals are all corroded), taping it all back up and rerouting some of the wiring in the process.
  2. #52
    Argentina
    Oh, and here is the front air dam if anyone didn't see it from another post -
    Attachment 18991
    I got it fitting reasonably well now after the trimming and bolting the ends up under the bumper. It is a little distorted in the first vent hole but I'm not sure if it's due to the air dam being a touch wider than the bumper or from the way it was mounted in the first place. I took a heat gun to it to 'sweat' the urethane back into looking fresher and shape it to fit a little better. The side wings still stick out all the way to the wheel arch lips but I can live with that.
    Can't wait to see this bolted on that front end. It looks awesome!
  3. #53
    I might dummy it in later with the grille and take pic of it when I'm not going at the speed of life lol. As mentioned, the wiring is a mess and I need to finish assembling the front end suspension with the Gen 2 hubs but time is one resource I don't get a lot of. Just keep chipping away at it whenever I can.
