Doctorates Degree
Thanks Bjamin
. I really am impressed with how that legit the cheap PU leather grain adhesive stuff looks. I took the passenger door card off and pulled the adhesive up in that one spot where it was looking janky. Came up easy enough and allowed me to take out the air bubble along the edge. Hopefully Bjamin you'll find a nicer dash pad to swap in. It's not impossible to fix a busted up pad but it is a lot of work. I haven't looked on ebay to see if there are bigger cuts of that adhesive PU leather but a sheet about double the width would be enough to cover a whole Gen 1 dash. They send it folded up so you will end up with fold lines in it but it's acceptable.
