could some one tell me where the plug is to fill the trans. on my 87 Ram 50? its a manual, if its the one I think it is, then it is stripped.
3/4 way up the drivers side of the case behind the bell housing!
Yep. Head bolt rounded off any ideas?
hf and sears sell bolt extractor kits that are sockets with teeth inside that will grip the head of the bolt so you can spin it out.
Awesome thanks pennyman. Do you know where I could get a replacement?
does anyone know of the bolt thread pitch and diameter of the plug?
PLUG. Transmission Case. . PLUG, PLUG, (16), PLUG, (16x16), PLUG, Case, PLUG, Case (16), PLUG, Case, (16), PLUG, Case, (16x16), PLUG, Filler, PLUG, Oil Fill, PLUG, Transfer Case, (16).
PLUG, (16x16). . Required: 01
Part# MD701850
Part is still available from Dodge it looks like!
md701850 is the plug and mf660036. Less than $5 in parts but $10 in shipping. OEMMITSUBISHIparts.com Need anything else to make it worth while? Let me know and ill look up the numbers for you. Clips? Trim ? They still have plastic interior parts for 2nd gen trucks but they are going obsolete because people don't want to invest $22 ea for things like Windshield pillar moldings or $8 for Door opening moldings (On floor).
sweet, would they have a front bumper assembly by chance?
Them bumper part can be found cheap at about any place that sells D50 parts.
yeah, I saw the Chrysler one too.![]()
awesome thanks for the help!![]()
If you need the brackets I might have a set around here someplace! (Cheap)
Havent checked the brackets... I will let you know tomorrow.![]()
MD951857 Mitsubishi Part No for bolt
MD951858 Mitsubishi Part No for gasket
That is an auto pic Brad he has a manual!
