Results 1 to 11 of 11
Thread: 4D55 diesel injectors
    graham,wa.
    1985 Mitsubishi Montero
    4D55
    I think I have a bad injector and I have searched high and low to find a replacement source, Does anyone know where a guy could find a vendor that actually carries rebuilt or new injectors for a 4D55 turbo 2.3. Is there an injector that will work as an upgrade from another diesel engine, I have a 1985 2.3 turbo diesel transplanted into a 1985 Mitsubishi Montero from a Dodge power ram 50.
    Farmington, UT
    1983 Mitsubishi Mighty Max
    4D56-T
    The dealer has new injectors. Also any competent diesel shop can rebuild or has a source that rebuilds injectors. Injectors are pretty easy to come by.
    Another Washtonian, Welcome to the forum. A couple more from Washington and we can take over the place.
    RockAuto.com maybe? There is a promo code also floating around here that can get a discount if they have them.
    Farmington, UT
    4D56-T
    Rockauto does not carry these injectors. They are a dealer part only.
    Call this place. http://www.diamonddiesel.com/
    All they do is fuel and turbos.
    New Orleans, LA
    someone is selling 4d55 injectors on ebay search on mighty max
    EastTX
    1984 Dodge Power Ram 50
    4D56-T
    I bought one from a UK vendor off Ebay. Works fine.
    graham,wa.
    4D55
    Thank's for the info guy's, I will check them out.
    Burbank, CA
    4D55-T
    Quote Originally Posted by 4D55 Performance View Post
    Spencer,
    You are misleading people. The injectors are OBSOLETE from the dealer as well as the tips. The tips are what wears out They were supplied by zexel Zexel is now made in china which is garbage.The part numbers cross to dense which are better. ANY diesel injection shop can order new Denso nozzles and install and pressure test and shim them. Cost is around $40-$50 depending on the shop.
    Burbank, CA
    4D55-T
    Again dealer OBSOLETE. I bought in the past the ones for the 4d55 ranger from rock auto. They had them for 85-86 and late 86 to early 87. Emmsions difference. I bought the cheapest ones. Beware rock auto catalog often sticks in gas engine parts with the diesel so make sure the picture looks like yours.
    Burbank, CA
    4D55-T
    By the way if anybody ever needs 4d55/4d56 injector washers and seals or even the fuel return line just text 8182683012 or email me mikewarme@yahoo.com. I have loads of the parts.
