Results 1 to 3 of 3
Thread: Engine Size
    United States
    Engine Size
    I know I came across a guide before on how to determine what engine I have, but I'm confused now.
    I've been assuming I have the 2.0 but the other day I tried a vin translation service and it says 2.6.
    How can I tell for sure which one I have?
    Thanks guys.
    First off it will tell you on the door sticker. Then if that does not look correct then does it have a manual trans or an auto. Then there is the Wiki that has pictures to help you figure out what you may have. You can also take a picture and post it up and someone will be able to tell by looking at it. Also there may still be the plate under the hood on the firewall.
    Check out the Fear Monger by
    Plate on the firewall will tell you engine code. G54b=2.6, g63b=2.0. To confirm this on the pass. side of the engine block behind the alternator is a flat spot with the engine code stamped on.
    Josh
    09 BMW 335i E92 Twin turbo
