Results 1 to 4 of 4
Thread: Emissions Delete
    las vegas,NV
    G64B
    Emissions Delete
    what are some of the things i can delete...
    Las Vegas, NV
    1991 Mitsubishi Mighty Max
    Everything if you never smog, or mind a CEL (if it throws).
    Usually buying the Weber carb makes the removal pretty much mandatory since 95% of the emissions crap is connected somehow to the carb or injection. If you want to get rid of the remaining 5% just go buy a header and that should finish it off with the catalyst. You probably want to make a small timing adjustment and keep an eye on spark plugs for any strange changes in mixture that possibly could happen. Other then that, go to town on it and we won't tell the EPA anything about it. Don't forget to plug the holes you make.
    las vegas,NV
    G64B
    yea i just want to clean it up, and delete the stuff thats not gonna be plugged in anymore
