Results 1 to 5 of 5
Thread: 4d55 head parts
    Northern Colorado United States
    4D55
    4d55 head parts
    Can anyone recommend a place to buy camshaft, valves, valve guides for the 4d55 head? I am rebuilding a 85 dodge Royal 50.
    Thanks for any help.
    Burbank, CA
    1983 Mitsubishi Mighty Max
    4D55-T
    Buy a whole new head. Its cheaper. Ebay. Get a 4d56 head from UK. The camshaft alone from the dealer is $320. The valves from mitsubishi are obsolete. Valves here in the states r almost impossible to find and if u find them they r chinese junk!
    Mike Warme 818 268 3012 Check your silencer shafts and oil pump carefully if doing engine!
    4D55
    Thanks Mike. will the original injectors work with these heads?
    Farmington, UT
    4D56-T
    If you have an 84-85 engine the the 4d56 head is a direct swap and the injectors should work.
    Burbank, CA
    4D55-T
    Thanks Spencer...... yes only the 83 injectors are not interchangable!
