The valve covers are the same also, though I am sure the cast is a little different with the design, but the holes line up. I have a valve cover for a 2.4 and almost put it on, but changed my mind as usual.
Your going to need timing belts, covers, gaskets, harness (not sure if connectors are a fit, radiator hose(pretty sure), these are off the top of my head. Best thing is check out DroppedMistu's build thread on this change. He went through this stuff and his thread is pretty good, minus the turbo unless you get a little inheritance somewhere
. You probably will find things along the way that you run into. Pretty good job to start your learning with, but you got good help behind you and here, You'll get it figured out.
