Results 1 to 21 of 21
Thread: Cab Seat ??????
    pa
    Question Cab Seat ??????
    Does anyone know what bench
    seat this is out of ? isuzu?
    thanks.
    Georgia
    1984 Dodge D-50
    4G63
    Dayyyyum.....don't know, but darn nice seat, and I'm jealous...................
    ~~~~~~My toys~~~~
    1984 Dodge D-50 (Daily driver, when raining)
    1990 Mitsubishi Mighty Max (Trying to figure out no power and sputtering)
    2006 Harley Davidson Heritage Softail (Rider when it's not raining and cold)
    1975 Honda CB750K5 (Rider when it's not raining and warm)
    1974 Honda CB350F1 (In paint for tins)
    1972 Honda CB175K6 (Just a rolling chassis, no engine)
    1972 Honda CB100K2 (Needs an engine, and rebuilding) (shhhh...if wife knew I had this, she be pizzzed)
    ~~~~~or headaches~~~~~
    Pukwana, SD
    Like to know that myself!
    Looks like it is out of a Mitsubishi truck, I can tell by the dash
    Pukwana, SD
    What's a good seat that would fit in the Gen II trucks, the stock "anti-lumbar" seats are tough on long trips?
    Georgia
    1984 Dodge D-50
    4G63
    ~~~~~~My toys~~~~
    Pukwana, SD
    Not much helpful info going on here! What seats do fit with the least amount of messing with? Buckets or bench as I have different seats in both of my D50 trucks that need replacing. I would like to know before I fork out the bucks.
    Las Vegas, NV
    1991 Mitsubishi Mighty Max
    Define "Messing with"
    It's up to your abilities. Can you cut and bend metal? or can you weld it too? Do you want a 100% drop in and go? or do you mind adapting one seat via some custom brackets you have to fabricate?
    My point is - you can add any seat you want to if you build the brackets to do so. Are you waiting for someone to come up with the info, or can you run to a junk yard and take a few hours to try some seats out?
    If you run to the yard, pick a half dozen seats to check out, you will find out real quick what will and will not fit, with or without mods. You can then come back here and share the info. In turn, you get a cool seat, and everyone will thank you. I think the most bucks I have ever spent getting into a junk yard was $5. That's not a huge loss to test out fitment.
    Pukwana, SD
    More worried about the fit, width wise the bracket I can make no problem, there must be a common vehicle (size wise) that are often used.
    Las Vegas, NV
    Go measure some seats
    Las Vegas, NV
    That seat actually looks like the back seat out of an SUV because it has no adjustment (if it did, it would probably be a front seat). Which one? I don't know.
    Any Fox-Body Ford or Pre 90 Escort/Lynx. Mine are from a 86 Escort GT and the inboard track bolts to the seat, the outboard needed an extension welded to the inside of the track to move the track 3/4" closer to the door to fit in the factory holes. I could have put the outboard rail on the seat and just drilled new holes.
ID:	9616Click image for larger version.
    Las Vegas, NV
    Here are 2 universal seats with flat sliders.
    Name:  Merrill Performance Seats.jpg
Size:  11.8 KBName:  Merrill Performance Seats 3.jpg
Size:  12.6 KBName:  Merrill Performance Seats 2.jpg
    Brackets were built to fit them. If you look on my build thread, post 89, you will get a better description
    blackwood, nj
    I used dodge neon seats. No brackets needed just a little cutting, welding and grinding. I took a hour to fit both seats and they're pretty comfortable.
    Pukwana, SD
    Thanks that helps a lot the closest late model bone yard is 120 miles away from here.
    I used Mitsubishi Eclipse seats and paid $17 for the pair, in fact any pair are $17 in our yards. For that price it was worth a couple extra holes in the floor board. These replaced old IROC bucket seats I had for years.
    Pukwana, SD
    I will run buckets in the X-cab one but I need to run a soild back bench for the longbed (tank) to hold my rifles to be handy. Any bench seat option that will fit the Gen II models?
    Las Vegas, NV
    I'm staring at a '95 Isuzu Trooper. The back seat looks exactly like the seat on post 1.
    I'll post a pic later when im not on my phone.
    Las Vegas, NV
    There it is....
    Pukwana, SD
    Thanks!
    pa
    Thanks merrill , thought it was from a isuzu rodeo,trooper......????? The stock max bench seat measures out to be
    bottom : 51 x 23 x 11
    top : 49 x 27 x 14
