Results 1 to 4 of 4
Thread: What is wrong here?
    Kuna, ID
    4G63
    What is wrong here?
    Replaced head gasket and other gaskets. new plugs turned distributor 180, new starter too. everything tdc when replaced. Idk whats going on but when I try to start the engine it wants to start it starts to fire then dies on me. at a loss again. 87 Ram 50 G63B 2.0.
    Auberry, CA
    Did you pull a plug while cranking it to see the condition of the spark? Getting fuel.
    This is a duplicate thread, he has 2 with the same problem shown. Might check for the other thread to answer.
    Here is his other thread which probably would be best to only use one.
    http://www.mightyram50.net/vbulletin...0053#post30053
    Kuna, ID
    4G63
    My bad. computer did it for some reason.
    yes i checked the plugs I want to say its getting full and is running a little lean.
