Are you sure you have the mechanical pump arm in the right way onto the cam - are you getting fuel flow from the pump to the carb? The big line coming from the frame goes to the inlet side of the pump (bottom), the line to the carb is the middle, and the small top fitting goes on the line back to the tank.
