Results 1 to 7 of 7
Thread: rebuilding auto lock hubs
    EastTX
    1984 Dodge Power Ram 50
    4D56-T
    I pulled a cover on an 84 auto locking hub and found a loose snap ring/retainer clip laying inside. I assume it's supposed to do something else. I just got the truck running again and haven't tried 4wd. I'm just looking at my options. Are they rebuildable by the semi dedicated weekend mechanic? Any input would be appreciated.
    Burbank, CA
    1983 Mitsubishi Mighty Max
    4D55-T
    Yes they are. Would you like a parts schematic? just need your email. You would be better off with a new set of manual hubs though........ Unless you want the originality? I did collect some new NOS auto hubs
    Pukwana, SD
    I cleaned and greased mine when I rebuilt my frontend on my 88 to get them working, I think that old grease was keeping them from working right.
    EastTX
    4D56-T
    I don't suppose you want to sell them.
    Stanwood, Wa.
    1987 Mitsubishi Mighty Max
    Mike -- What would a pair of manual hubs cost, shipped to Stanwood, WA 98292? Are they a direct bolt in replacement for auto hubs?
    Law Dog -- The manual says something about needing to press some components in and out to service the hub. Sounds like a pain in the rear. Did you have to take them completely apart to clean and lube or were you able to stop short of that?
    Pukwana, SD
    I flushed and blew out the old dirty grease from the hubs without taking it apart, washed out with gas and used compressor air then just re-greased them and they worked fine.
    Stanwood, Wa.
    Hey, that sounds like something I can handle. Thanks!
