Results 1 to 6 of 6
Thread: ranger headlights mod?
    Stuarts Draft, Va.
    just seen on another site a guy modded some ford ranger headlights and put on his MM, they looked flipped to form with the grill. anyone know how to do this and have any info about it?
    WA
    I thought about doing it. But spent the cash on a conversion bulb to h4, and used a spare HID kit from my civic. You have to modify the grill to accept it, and may tweek the radiator support a bit to fit the rear of the housings for the ranger set. If you don't modify the grill, the housings will extend into the marker lights location.
    1989 Mitsubishi mightymax; 1990 4g63 6 bolt swap: malhe 9.0 pistons, eagle h beam rods, acl race bearings, rebuilt head, evo 3 16g, aem afpr, Maft, 3" gm maf blow through, walbro 255 fuel pump, hks ssq bov, fmic, coil over plug, FIC 750 injectors, dsmlink, apexi avcr, AEM eugo, s90 throttlebody, JMF FIAC block off plate. LT1 T56 in the works, RIP km132.
    Why a mightymax? Why not? 18 psi FTW.
    Stuarts Draft, Va.
    damn that sucks, that mod does look good on these trucks. anyone ever played around or know of any other possible mods? im ok with grill modding but not interested in changing anything else that I cant easily buy from a scrap yard
    I did it on my old single cab, flipped and swapped sides to match the 90-92 grille. It looks awesome, but they wont aim light properly. You can see and drive but they aim a little low like this. I plan to do a custom sheetmetal front end later on on my ext cab with new grille and everything to properly use them the correct way.
    Josh
    09 BMW 335i E92 Twin turbo
    Georgia
    What year model ranger headlights are we talking about?
    Just curious as to which ones "fit."
    01ish, there is a lot of cutting the grille and lil bit of core support still to get them to "fit"
    Josh
