Results 1 to 25 of 36
Thread: somethings just not right.
    Stuarts Draft, Va.
    im hopiong to gut my cat tomorrow and im going in the morning to finally order my timing belt and tensioners, he said if i order tomorrow itll be here on the 2nd!! and im gettin my valve cover gasket(leaking oil), royster and I are working something out on the harmonic balancer(he has one) so hopefully ill have that done asap too. ill have to check funds but i dont think i have enough saved back to get the weber for another month. but im hoping with the balancer and the timing belt i can set the timing properlly and ill be good hopefully for a while without the weber. and ill see how much the pcv is in the mornin when i order my other stuff and instead of cleaning ill just throw a new on in. and egr? ill have to figure that one out. if it can be deleted ill prolly just go that route.
    Eastman, GA
    Quote Originally Posted by ram50bam View Post
    ill see how much the pcv is .
    Where I work I was able to get mine for $3 and some change. Retail for about $4 - $5. It is pretty cheap. no reason why you shouldn't swap it out anyway.
