hi guys im new here, i am about to start build for my mighty max, going to be a daliy driver fun truck
im going to do a sohc 4g64 with about 8 - 10lbs of boost on average, but wanna turn it up to 12-15 once in a while
i was wondering what pistons should i use and were can i get them?
i read on other sites that my stock rods and crank will hold that amount of power is this true?
the head is a sohc 8v unit, im going to port and polish, 1mm over valves and 5angle valve job, and maybe a cam regrind but unsure yet
were can i get upgraded springs, lifters and valves?
wanna use megasquirt but unsure of which one to use?
will a td05 be a good size turbo for this setup?
can i use upgraded fuel rail, fuel press regulator and injectors (think they are 550s) and walbro 255 pump for a 2.4 sohc eclipse ( can get free)
i know that i can use the exhaust manifold off of a 4g63t( also free)
what elese can i use off of 4g63t i have a friend that has alot of parts for one.
thanks for the help
comments and sugestions are welcome
. but on a brighter note im probally gonna listen to everyone and go with the head swap, even better got 2 4g63t heads (1g an 2g) another running mighty max spare motor but its a 94 7bolt (complete), alll for only $100
