Senior
here is what I did so far since I drove this puppy home:
1. Oil change: used Delo 400, substituted one quart of that with Riselone. Added the ZDP addetive. used Purolator One premium filter (No shitty fram for me!)
2. Changed all 4 spark plugs, using NGK v-powers. Gapped them to spec at .040
3. Changed all plug wires one and a time as to not mess up the firing order.
4. Used Lucas fuel treatment with every fill up (I noticed MPG and HP gain after the second fill up!)
Here is the probelm check list so far.
1. No Vacuum leak
2. Throttle is not loos nor to tight.
3. I will be swapping the distributor cap and rotor on Monday (my Day off) and speed test again.
