Results 1 to 11 of 11
Thread: Coilovers??
    United States
    1991 Mitsubishi Mighty Max
    Coilovers??
    New here but I was told that Coilovers from a s10 would work anybody here
    have or are running Coilovers just for the front I'm trying to go low in the front
    but need help deciding on what I really want
    the front shocks on these trucks are the same length as the 1st gen s10s so they may work.
    United States
    I would like to do my suspension right the first time around so Ima try Coilovers in the front
    and later on 4 link the rear but I'm building a 4g63 swap now
    Anything can be done, you just need to find the length of a s10 coil over and measure the truck and see if it will put you where you want your truck.
    Josh
    09 BMW 335i E92 Twin turbo
    Las Vegas, NV
    The spring perch of the S10 is higher tham the MM. The shock is almost identical. Chances are it wont work unless you get a custom spring.
    I was going to go this route in the beginning, but I'm not spending the money based on those measurements.
    United States
    I wish I could mod up some of my 240sx coilovers but highly doubt
    it but I love them.
    tein coilovers
    Farmington, UT
    1983 Mitsubishi Mighty Max
    4D56-T
    I know that Fox coilovers fit.
    United States
    Im looking to go lower or I would cop a pair.
    I'm just seeing how other people lowered theirs before I
    go and spend money
    Mostly drop coils blocks and bags in this site. Don't think I've seen anyone run coilovers on these, plenty on Hard bodies and such
    Josh
    Las Vegas, NV
    I still have other repairs and fab needed to do on my ride, but I'm going to use coilovers as soon as the time comes. There isnt a ton of room up front, so some reconstruction will probably have to take place depending on your design. I have to build my own control arms to adapt everything I intend to use.
    United States
    Guess ill wait and see what kind of designs I can draw up
    for a custom setup.
    I know alot of 240sx people that did fab work so ill
    do some research and make a thread when I start mine.
