Results 1 to 3 of 3
Thread: Center Console
    Sacramento,CA
    1986 Dodge Ram 50
    Center Console
    I have an '86 Ram 50 that I'm taking out the bench and putting a set of bucket seats I have, any ideas on a center console that will work and look nice?
    I've added a few things to my 86 Ram50, A/C P/S found a new makuni carb on Ebay. just got a new 100 amp Delco alternator I'm putting on it also have a Tach cluster I bought from another member and a overdrive automatic trans when find a wide block 2.0 eventually I'll get around to painting it.
    1998 Ford Explorer
    1986 Dodge Ram 50
    delavan wi
    Walmart has some generic ones that should fit if you want to go cheap
    As I said in the album, this is nothing to brag about, it holds coffee, coins and pencils. It's two cheapie cup holders (as thefreack says, from Wal-Mart) fused together, and an after-market shifter boot with chrome retaining ring. As a carpenter, I should be making a really cool one, but there's other priorities in my neck of the woods, right now.
    Not that it's of any import, but the underside is filled with expanding foam, then trimmed to fit the floorboard hump. ("Floorboard hump" sounds like a dance, a bad rock band or a perverted sex position...)
    If you don't have a factory dash clock, you can tap into the dash-lights connector and illuminate a console, should you want. (Think 'Meatloaf' - "Paradise by The Dashboard Lights", a song about attempting the Floorboard Hump).
    http://www.youtube.com/watch?v=C11MzbEcHlw
