Results 1 to 6 of 6
Thread: steering gear leaks
    San Diego, CA
    1983 Mitsubishi Mighty Max
    4D55
    steering gear leaks
    I have 1st gen 4x4 power steering gear leaking at top of unit, seems to be at lash adjustment screw so I put brass washer under lock nut. Its still leaking. Should I take top cover off and cut new gasket for it? Is there an internal leak? I replaced previous gear with this one because it leaked out bottom at pitman arm shaft. Time for another or can I fix it?
    Fayetteville, NC
    Did anything ever come of this issue, I am having the same problem on my 87 2wd Ram 50
    Oakland, CA
    Rock Auto to the rescue. They have rebuild kits for sale.
    sheffield, vt
    1978 Dodge D-50
    had the same issue with the 83 4x4...did the rock auto rebuild...lasted a month (hopefully you will have better luck...price is reasonable to try). ended up swopping out with the 1986 parts truck (that I rebuilt with factory components in 1991) only to find the pitman arm splines are larger on the 1986 (but luckily had a good pitman arm...broke my pitman puller). Been about 4 months now...no leaks...very responsive & no steer "wandering"...life is smooth sailing once again.
    these boxes have the tendancy to wear oval shape on the shafts, usually the one to the pitman arm. If that happens, new seals are just a stopgap until the casing gets new bushings and bearings to fix the slop. That is why rebuilt boxes cost so much - the bearings are custom made to fix the box, no factory ones are available.
    Fayetteville, NC
    Hmm since I don't drive her daily I think I am going to give the repair kit from rockauto a shot. Was the gear difficult to take out? I removed the driver side tire and lifted the truck breifly the other day just to get a better look, seems like it could be a pain to pull out.
