Thanks Ethan, smoothing it all took a lot of work.
The red oil drain hose for the turbo drops straight down and then bends gradually, i think the pic makes it look a little worse then it actually is. I check it all the time and there is no kink yet, thanks for the suggestion though. I do plan on replacing it and a lot of the other lines with stainless braided hose and an fittings, just dont have the money right now.
The steering wheel is from a 1st gen DSM(eclipse,talon,laser). Bolts right on all you have to do is enlarge the opening for tue wheel in the steering column covers.
