Results 1 to 8 of 8
Thread: Best engine oil to use
    Canada
    1986 Dodge D-50
    4D55-T
    about to do the oil in my 4d55 engine. what would be the BEST choice to put and is lucas oil stabilizer a good thing to put in with it thanks. It leaks a SMALL amount of oil so im thinking something thicker with a lucas additive to thicken it a bit until i can pull the engine and re-seal it with new rings/bearings/belts & a 4d56 head.
    Dello 400 no need for additives
    Canada
    1986 Dodge D-50
    4D55-T
    what weight oil would be best?? Full Synthetic i take it?
    15w-40 conventional oil - synthetic will run right through seals that are already leaking.
    Canada
    1986 Dodge D-50
    4D55-T
    thanks!
    It's whatever you like. I would read about the oil weight. I hear 30 wt is favored for general use, though I use other wt and Castrol.
    Canada
    1986 Dodge D-50
    4D55-T
    thanks, oh and how many quarts do i need to make the oil change??? Will be replacing filter obviously too.
    Canada
    1986 Dodge D-50
    4D55-T
    found the 4d55 oil capacity.
    6.5 Liters including the oil filter and oil cooler. (.6 in filter, .4 in oil cooler)
    So 6.1 Liters is needed to make an oil change if you are changing filter but not draining oil cooler!
