It might be hoping for too much, but I hope this all means you'll be driving that truck by Sunday!
An ounce of prevention, perhaps you could get that cylinder TDC and try to get a vacuum cleaner attachment to fit up to the spark plug hole (or even better, in it) and suck out any Jimmy Hoffa leftovers in there. I supposed blowing it out with compressed ait would work, too. So...suck or blow, your choice!I hope that the end off of that one jet valve is not laying down in that cylinder, I took my pin magnet and ran it down that cylinder and found nothing.
I'm curious how you did that, but my guess is you pulled them through the cylinder with some needle-nose pliers. Do tell us your secrets!I got all 4 of the jet valves out of the head now
I don't mean to be telling you things you already know: just pointing out in case it got over-looked. You're 2 years older than me and have just that much more experience, so please know I speak with utmost respect.
I suspect you'll want to weld those ports from the cyclinder-side eventually, to prevent weld-boogars from getting hot and causing dieseling.
