Results 1 to 9 of 9
Thread: 94' Mgihty Max stacked rod bearing
    Carrollton GAA
    Got a 94' 2.4 5 speed Mighty Max that stacked the #1 rod bearing everyone is telling me the rod is junk now.. idk, I think the rod will be ok.. how long would it last if I just threw a crank kit in it without replacing the rod...
    Columbus, OH
    better known as Spun Rod bearings....The crank and whatever rods spun will need work. You will need crank bearings rods( Spun ones) and luck.
    Carrollton GAA
    so you dont think it would be ok to put a crank kit in it?
    http://www.autozone.com/autozone/par...6590_124645_0_
    along with a rod for the one that spun, otherwise you get to do it again.
    Carrollton GAA
    that means pulling the head.. :/ ok well figured I'd ask.
    Columbus, OH
    Yeah, tough shoving the pistons in from the bottom, eh? sounds like a little "re-fresh" coming. How many Miles?
    BTW the link you posted was for a 7 bolt Crank, you have a 6 bolt.
    Carrollton GAA
    I was told it wasn't the original motor but the odometer reads 200,175 miiles
    And what tells you I have a 6 bolt crank?
    The year of the truck/engine
    Carrollton GAA
    Ok what year trucks come with a 7bolt crank cause the motor that come out is a 7bolt, I hva e a 1990 Mighty Max with the original motor that was a 6 bolt
