Results 1 to 18 of 18
Thread: The little black truck gets a big block
    Kansas City, Kansas
    1987 Dodge D-50
    Dodge V8
    I have had this 1987 D50 for 3+ years,
    It has been part daily driver, and part backup vehicle.
    It is in daily driver mode right now, but will be moving to motor swap soon.
    I have seen and heard about small swaps and associated issues.
    I have decided to go big block Mopar. Part of the reason I the distributor location, and part is because I already have the 383, heads, cam, timing, etc.
    I picked up an Offy intake to go on the engine, and have a 650 spread bore, double pump carb (think Q jet replacement), that should give plenty of pep, plenty of vacuum signal, etc.
    I will post pics of truck as it sits now, and progress of the engine,.
    Long term will probably include cutting down a C body 8.75 housing, custom axles to keep the stock wheels (I like the 5 spoke Bogart look), and probably a 3.23 or less gearing to make it highway driveable. '
    Updates to come.
    a 8.75 from an A body mopar fits without cutting if you can find one - same 5 x 4.5 bolt pattern. At least its not the carter thermobog carb it came with - or you could got fast efi or holley projection 4. Pics please!
    Kansas City, Kansas
    1987 Dodge D-50
    Dodge V8
    My truck is 6 lug. Plans are to cut down the longer C body axle, and order new HE axles in the right bolt pattern to keep the 6 lug 5 spoke wheels...
    that is different what about the brakes - you may be able to use front rotors off of k1500 chevy 4wd trucks and fab a bracket for calipers, or go wilwood or ssbc
    Kansas City, Kansas
    1987 Dodge D-50
    Dodge V8
    Definitely have to figure something out. May try to keep it 6 lug drum of some sort, but haven't got that far just yet. Right now I am trying to keep it roadworthy for daily driver use, but damn. It leaks gas and oil at astounding rates. Gonna lift the bed tomorrow night, and see if I can figure out where it's leaking underhood.
    Kansas City, Kansas
    1987 Dodge D-50
    Dodge V8
    Here is how she looked several years ago, when she was drug home...
    Kansas City, Kansas
    1987 Dodge D-50
    Dodge V8
    Kansas City, Kansas
    1987 Dodge D-50
    Dodge V8
    Here she is now...
    Kansas City, Kansas
    1987 Dodge D-50
    Dodge V8
    The 383...
    Kansas City, Kansas
    1987 Dodge D-50
    Dodge V8
    The needed a replacement piston. It has new bearings, a split duration Summit Racing cam of some sort, timing set, oil pump and pick up, gaskets, etc. I have already trimmed the tab on the block to use the shorty stainless headers from Ebay. It should keep the entire combo relatively narrow.
    I am going to pick up a core 727 and have a friend run through it. I also have a T handle shifter from B&M that a friend didn't need, but I might look at one of the narrow pistol grip style shifters for clearance in the cab.
    be sure he replaces the sprags in that tranny - the one weak part in a 727.
    Kansas City, Kansas
    1987 Dodge D-50
    Dodge V8
    Before the heads and intake go on, I am going to do a basic port job on the heads. I will probably not even bother with a valve job, just a basic port cleanup, bowl cleanup, and some red scotch brite cleanup. I will decarbon the valves while they are out.
    Kansas City, Kansas
    1987 Dodge D-50
    Dodge V8
    This one will probably not see the track, so the sprags and the drums won't take too much of a beating. Hoping to keep all the hard parts in the trans, trying to do this whole job on the cheap.
    A radiator is probably going to be the highest cost item.
    you are right there might as well do the whole job - the valves have to come out to do the porting anyways
    NW mississippi yall
    Dodge V8
    Any updates?
    I found out with mine that a later Magnum "ROLLER" block isn't the best motor since the starter and steering box wants to sit in the same place..
    NOW I get to weld in a steering rack and MAKE IT WORK..
    E
    Alabama
    Dodge V8
    I have a stroked 340 (394) in my 1980 D50. It is a pump gas motor and made 662hp and 533 tq. There is plenty of room for a small block. I had to build my own headers. Ran a best of 6.21 @110 in the 1/8. I can drive it anywhere.
    Alabama
    Dodge V8
    Picture..
    North Greensboro, Nc
    1987 Mitsubishi Mighty Max
    ^ the want is strong with this one.
