Results 1 to 3 of 3
Thread: Cap and rotor short wear life
    Burbank Ca
    4G72
    I have a 94 mighty max 3.0L. less then a few thousand miles ago I replaced the cap and rotor. Now the problem is back again. This is crazy. $40 in parts every few months. I change oil less often that that. Anyone have any suggestions on how to solve this problem? All stock parts with an intake. Estimated 228 on the clock.
    Can you post up some pictures of what it looks like inside and what is going on. Need more info to try and help out.
    if the rotor is cutting into the cap, the bearings in the distributor are shot, causing the shaft to wobble.
