Results 1 to 6 of 6
Thread: Doing An Alignment sort of....
    San Diego, CA
    G64B
    I put my truck on the alignment machine the other day because the front tires wear on the inside tread pretty fast, I realized that I upper control is mounted to the inside of the frame. So I cant adjust it, should also note that all my suspension and steering bushings and ball joints are shot out. Is possible that the frame is bent or warped?
    Orlando, FL
    G64B
    Portland, OR
    It's the lower control arm bushings.
    San Diego, CA
    G64B
    I don't remember what machine I think it is hunter winalignment something something dark side.... anyways if I shim it, it will only make it worse. So my lower control arm bushing should fix that then. Worth a shot. Thanks man.
    Grants,NM
    1985 Dodge D-50
    Chevy V8
    be sure to get poly proformance type bushings.
    Grants,NM
    1985 Dodge D-50
    Chevy V8
    just an update. energy suspension part number 5-3102g black or 5-3102r red.
    real easy to install.
