Results 1 to 6 of 6
Thread: master cylinder question
    lexington sc
    Doing the 5.0 swap have a 90 max which is a cable clutch thinking of grabbing a 5 speed out of a 90's f150 for the hydraulic clutch, do any max's come with a hydraulic clutch that I can swap the master out of?
    Oakland, CA
    Some guys use the Starion MC, other's buy a Wilwood.
    Check out Project Zero G, there's a ton of information on swaps there.
    https://www.google.com/search?q=proj...00&newwindow=1
    86 and below diesel trucks use a hydraulic clutch, same with the 90-96 v6 4x4 trucks
    lexington sc
    Is the master bolt in, just have to fab the pedal
    I don't think so but I havent done the swap yet. I believe there is a little bit of fab, not much though.
    have to fab plates to reinforce the firewall for the master cylinder mount, or it will flex too much for good operation.
