the final gear goes in the rear end the different trannys just were built with different sets and pennyman the gears fit all they just dont bolt in to the carrier you have to actually swap the ring and pinion and if i could find an auto mm in a jy i would do that instead and if i could find a lsd that would be icing on the cake to swap in lower gears and an lsd at the same time
