Results 1 to 8 of 8
Thread: Fuel Pump Rewire Like The DSMers
    Las Vegas, NV
    G64B
    So has anybody straight line grounded their fuel pump to the battery for increased flow the way the DSM'ers do?
    Here's a link to one VFAQ if you don't know what I'm talking about...
    http://www.plymouthlaser.com/fwdwire.htm
    I've searched the site and found no definite evidence of "yes". I see lots about converting from mechanical to electrical - seems lots to do about the Carb trucks. But what about the EFI guys? Looks like everybody goes straight to the DOHC turbo swap, am I right?
    I'm not in a position to do the turbo swap right now so I'm trying to squeeze as much performance out of the stock motor as possible for as little money as possible. But a little more fuel flow from the rewire (especially if I upgrade the pump as well) with maybe a cone filter for a little more airflow to go with and I may have at least a few more Ponies/Pound-Feet. Can somebody with experience speak on this?
    I have done the same rewire for Geronimo for my electric fuel pump by mounting the fuel pump relay about 1 foot from the pump, with a 12 GA wire from the battery to the relay, and a 12 GA wire back to the battery for ground. It solved the voltage drop issue I was seeing to the pump. Your idea should help give the max your pump can give - I have also put in a set of relays tied to the battery for the headlights for the same reason - eliminate the voltage drop.
    Las Vegas, NV
    G64B
    I have done the same rewire for Geronimo for my electric fuel pump by mounting the fuel pump relay about 1 foot from the pump, with a 12 GA wire from the battery to the relay, and a 12 GA wire back to the battery. It solved the voltage drop issue I was seeing to the pump. Your idea should help give the max your pump can give - I have also put in a set of relays tied to the battery for the headlights for the same reason - eliminate the voltage drop.
    Sweet! Got any pics?
    Not at the moment - I can get them when I go to my buddies house which has a lift. Keep in mind Geronimo is a carbed truck, but this setup will still work for what you want to do.
    richmond, va
    4G63
    i'm not even sure of what you guys talk of as i have not experienced fuel shortages etc...what years does this occur in i have a talon 95 and 02 neon. The neon will cut fuel if certain conditions do not exist. this is the ecu...and pcu... circumventing an issue usually isn't good. Pushing your fuel pump harder is not gonna matter if your can't adjust your fuel pressure regulator or AFR...your just gonna stir up fuel more, as it would just return the over pressure back to the tank... which might actually boost performance a bit. A carburated engine, would just dump fuel into the engine, but is much easier to adjust afr...Just curious first i've heard of this. would love to buy a 4g63 truck...and these things sopposedly had them factory?
    Voltage drop is what they are trying to fix and what the eclipses(DSMs) experience. It is mostly needed and becomes apparent when people start upping the boost on their turbod engines and the fuel pump can't keep up because of the voltage drop.
    These trucks did not come with the dohc 4g63 like the dsms but a sohc carbed g63b
    Josh
    09 BMW 335i E92 Twin turbo
    Las Vegas, NV
    G64B
    Actually found out I have very consistent 14.8v from the pump and, like Dropped said, I don't need to do the rewire. IDK if it's because of the ground wire system I "built" for my truck or not, but I just left well enough alone on this one.
    North West Florida
    Iv'e never seen a need for this mod either. But alot of DSM guys do it to their cars, not that a mob mentality is correct, but it is not surprising it came up here.
