Hi there. I was just sent your way by a couple of forum members, 85Ram50 and Pennyman1. Ive just got hold of an '88 2.0L with about 160K miles on it.
took it in to a test-only station, but they wouldnt even touch it, as it had an after market cat on it with no CA stamp.
I then took it to a STAR garage to have a preliminary smog test done... passed visual/functional, but qualified as a gross poluter at 15mph, with HC at 137 and NOx at 2487(!)
Ive replaced the cat with a magnaflow that has a Dxxx-xxx stamp, and replaced the O2 sensor. I took the EGR off to see if it was crusted up with carbon, but instead saw that it had oil in it (which smelled like gasoline). EGR passed the finger test, but im confused about the oil. Could it be PCV related?
What do you think about those emissions levels? Any thoughts, ideas or suggestions sure would be appreciated!
Thanks from SF!
