There should be no vacuum at idle. The functional test to see if the EGR is working properly is to disconnect the vac line with the engine warmed up and idling and apply vacuum with a handheld pump until the engine stumbles. It should start stumbling be around 5 psi. EGR helps cut down on NOx, it reburns unburned exhaust. Sometimes they get clogged with soot, if it's fouled up, take it off and clean it out with carb cleaner and a wire brush.
