You can view the page at http://www.mightyram50.net/vbulletin...-D-50-Geronimo
My Ram 50 has both those problem. Was the Weber worth the 300 dollers?
yes definitely, i would go for the DGV series, the 2 of my liking are the 32/36 progressive as it bolts right onto the intake no prob, and the 38/38 synchronous as it is 400 and the recommended carb is a 400. You will need a special spacer to adapt to it, get a 38 to 32 spacer and take it to a machine shop, they can then make it a 38 38 to 32 36 spacer.
