Results 1 to 12 of 12
Thread: Painting carpet
    blackwood, nj
    Painting carpet
    Has anyone used duplicolor fabric paint on their carpet? I'm thinking about painting it black. I know a detailer who says he does it all the time. I'm just wondering if anyone else has with good results.
    I have tried it before - be sure the carpet is spotless for the best color change. I have also known people that have used regular spray paint to dye the carpet.
    blackwood, nj
    cool thanks. i've heard of people using regular spray paint also. i'm wondering if the fabric paint would hold up better.
    actually the spray paint made to stick to plastic should work as well as the fabric paint
    Oakland, CA
    I had a friend use RIT dye and pots of boiling hot water in a kiddie splash pool from Wal-Mart. Seemed to work pretty well.
    San Diego, CA
    G64B
    Where can I find a decent carpet for my first gen other than the junk yard. Has any used a carpet off a different vehicle with some trimmimg herend there?
    Tons of company's online still have them for under $150 new.
    Oakland, CA
    I used this company for an old Impeza, fit OK but you definitely have to trim it a bit and have a heat gun to massage it into place.
    http://www.stockinteriors.com/items....p_Truck_Carpet
    WA
    When I bought both of my 4x4's, the first thing I did was remove the carpet, suspend it from a clothes line and take the pressure washer to it. They both cleaned up surprisingly well. Unless yours is really ripped up, you might want to give it a try. You obviously want to use the widest spray nozzle and hit it from both sides. I had a little berm of mud under mine when I finished, it's amazing how much dirt the carpet can hold.
    1990 MM 4x4 3.0
    1991 MM 4x4 3.0 Diamonte
    Auto custom carpets make the best fitting carpets for the 1st gen trucks and if you watch on ebay, sometimes they go cheap - the last one I bought was like 80 shipped, and it was even the color I wanted.
    San Diego, CA
    G64B
    sweet, i ripped mine out a while back because I spilled old gear oil on it. Might try cleaning it, see how that goes.
    pennington gap,va
    1982 Dodge Power Ram 50
    the dye is wayyyy better (aerosol)avail at napa 1 12 dollar can should do it but two would leave you some for other parts its also for vinyl and about
    the gear lube try purple power/stuff thats what i used when i stepped on a full jug of gear oil in my ram 1500 after using a gallon and multiple vacums&scrubbing it dosent smell any more
