I'll look around. Or I'll send flywheel to top end and let them lighten it and redrill for the bigger clutch. Idk yet.
Originally Posted by Uneek98 I'll look around. Or I'll send flywheel to top end and let them lighten it and redrill for the bigger clutch. Idk yet. Do you really want a bigger clutch? Or a stronger clutch,You won't get a bigger clutch for that flywheel,diesel clutch kit is generally stronger .
Originally Posted by Kiwi minitruck Do you really want a bigger clutch? Or a stronger clutch,You won't get a bigger clutch for that flywheel,diesel clutch kit is generally stronger . If I have them redrill it they will take it from a 225mm to 240mm. So that's a little bigger and a little stronger.
