Originally Posted by
pennyman1
have the rotating assembly balanced and blueprinted - this matches the weights of each part to the lowest part of its type and is necessary when building up a non-balance shaft motor with a lightened flywheel. Look in our manual section for the mopar performance guide section on the mitsubishi engines - lot of good info on porting the head and other details about the early 2.0 and 2.6 motors.
