About to order some hood pins for the mightymax
The hood wabbles a bit in speeds above 70. This is because I removed the center brace for the hood latch to make room for the intercooler. If I attach the hood latch onto the intercooler, it will pretty much be the same as it is now. Has anyone installed good pins in their mightymax able to take a picture for me. Would like to see some installed before I buy them from amazon. I am currently eyeing out the sparco red hood pins because they look similar to the hayame ones I had on my civic. The cheaper one on amazon has an aluminum stud instead of the steel stud the sparco set has.
Again. Pics of your setup installed if you installed hood pins.
I have these on my build truck. Nice tight fit and don't crack fiberglass.
Autofab.... http://autofab.com/i-9943226-autofab-hood-pin-kit.html
