Results 1 to 4 of 4
Thread: 1986 ford ranger 4d55 diesel
    hammondsport ny
    4D55
    Hey guys just joined the site. Im own a 86 ranger with a 4d55 turbo diesel. I see a lot more info on here about 4d55 then ranger sites i belong to. Just curious if any of you know what ranger transmissions will bolt to the 4d. Reason Im asking is my ranger is a 2wd and Im gathering parts for solid axle swap. Have axles and most suspension parts. Thanks guys
    hammondsport ny
    4D55
    Its a 5 speed manual would like to keep it that way.
    lmao , your name doesn't fit in the column... that is too funny. You can explore our wiki section for good info and we also have an auto manual download area that are a great help. Cruise the forum and get comfortable and there should be someone to chime in and help you out. You probably could locate that question's answer here somewhere. Use our search and advance search also on top right of the pages.
    Welcome to the Forum.
    *BUILT & OWN*
    '86 Mitsubishi Mighty Max ("Mitsy") The Build History
    "1st Gen Japanese Vehicles"
    '86 Mitsubishi Mighty Max -(Purchased '87)
    '89 Toyota MR2 GT -(Purchased '08)
    '74 Toyota Celica GT -(Purchased '76-Sold '12)
    "Ford Thunderbirds"
    '85 5.0 302 Thunderbird -(Purchased '14)"Muscle Car"
    '88 3.8 V6 EFI Thunderbird -(Purchased '19)
    New Bern, NC
    1986 Dodge D-50
    If it uses anything like the mitsu and dodge's do then you can swap the tailshaft with a transfer case and vice versa. If it uses a ford tranny then good luck with anything :p
