these are the headlights i have on my truck upgrade to the 100w/55w or 100w/90w http://www.ebay.com/itm/200mm-H6054-...item4d0b060897
here's a follow-up on these.
These lights can come with what's called a "city lights" option, the city lights DO NOT FIT our trucks without a modification to the back of the headlight mounting bucket. If you order the CL option and then do not modify the mounting buckets you will be left with an open hole in the bottom of the headlight which will allow moisture and dirt in to cloud the lens and shorten the bulb life.
Our trucks are also not wired for the CL. I solved that by cutting the pigtails for the front marker lights from my parts truck and wiring them into my front marker light circuit so it all looks stock. That's where I ended when I discovered the interference issue - I'll update again when I finish.
As for the ceramic light socket pigtails, they are direct fit harness extensions and work perfectly.
