1983 weber
Hey guys im looking at buying a weber carb for my 83 ram 50 2.0L and i just want to double check with you guys if its the correct carb for my application... want to double check before i buy it... thanks
uhhh that is very expensive. I paid maybe $225 for mine and it looks the same, but I see prices have gone up some. There are 2 aluminum threaded plugs and one will replace the tubing that is removed from the exhaust manifold. They are useless and will wiggle loose every time. You may want to pick up an old junk yard tube with the bolt on it and cut tube short and bend over the cut end to create an air tight adapter. Place this into the exhaust hole instead of those plugs supplied.
I'm not sure if the 38 is the one you want also. Unless you have other modifications done to your motor. I think most of us purchased the K610 progressive 32/36 with an electric choke. Made in Spain.
Kit #K 610
http://www.ebay.com/itm/K610-DODGE-D...204#vi-content
US $239.95
http://www.racetep.com/cheapweber.html
This site says they will beat any price.
Be sure it is made in Spain, there are some copycat weber carbs out that are junk.
I used this one for a 86 2.0L Mits
Inactive
http://genuineweber.blogspot.com/ this how you tell the diffrence.. i had bought the "fake" weber and it is junk
