IIIIIMMM back...with more problems. So I tried the ground the ECU trick to put her in timing mode, and it runs so smooth. Heres the problem, when I get the timing right, and unplug the ground, it runs like complete garbage again. The AC makes a horrible whine and it runs like it is way out of time. It would die at a complete stop if I didnt give it a little gas while braking. I replaced all the vacuum lines and I just dont know what to do. What would the downfall of just keeping the ecu grounded? Like I said it runs beautifully when its grounded, I just need to know the long terms effects.
