Well I adjusted the timing last night and it seems to be running much better. It wasn't even close. When I installed the timing belt I did match up with the correct mark on the head. I drove it home on the interstate last night and checked the codes again. I'm still getting the code 42 which is driving me nuts since I changed the fuel pump, strainer and filter. Any ideas of what else could be causing the code 42.
