Results 1 to 9 of 9
Thread: rim question
    Charles City, VA
    rim question
    will chevy 6 lug 17inch rims off a 2011 silverado fit my truck???http://norfolk.craigslist.org/pts/2348783748.html
    Orange Park, FL
    Yes and no. The center hub diameter on those rims is likely the usual 78.1mm which you would find on a chevy, but you need 108mm to clear your hub. So if you get them, and bore the hub, then they'll fit. Otherwise they wont just bolt right on. No idea on the offset of those, but that would also be something to look in to.
    Yes they are the right bolt pattern but the hub bore is too small, so you need to bore out the hubs or turn down the centering runs on your trrucks brake hubs
    They should tuck also.
    Charles City, VA
    also what about escalade rims i heard they will bolt right on??
    Any chevy/gmc(caddy) wheel will need to be bored or your hubs turned down.
    Stafford, VA
    Chevy V8
    i think any gm rim will need to be bored...if i am not mistaken.
    oh and i am from VA too. stafford to be exact. you are about hour and a half away....
    WA
    You may get away with most of not all Toyota 6x5.5 rims without having to do any type of modification to the rim or hub. I am using 15" chrome pathfinder rims on my mightymax. Look way better then the stockers.
    Stafford, VA
    Chevy V8
    pathies are one of my favorite rims...they are sweet..i have had them on all my truck so far......
    Charles City, VA
    thats pretty sweet finally some one whos close to me!!
