Results 1 to 6 of 6
Thread: help help help !!!!!
    Wichita ks
    hello ! anybody knows if it's any difference between the engine for 92 mighty max2.4 and 94 mighty max 2.4??? because i found a remanucfactured engine for 92 mighty max, this engine will fit my 94 mighty max 2.4??? thanks
    As long as both motors are 7-bolts I think your fine.
    *BUILT & OWN*
    '86 Mitsubishi Mighty Max ("Mitsy") The Build History
    "1st Gen Japanese Vehicles"
    '86 Mitsubishi Mighty Max -(Purchased '87)
    '89 Toyota MR2 GT -(Purchased '08)
    '74 Toyota Celica GT -(Purchased '76-Sold '12)
    "Ford Thunderbirds"
    '85 5.0 302 Thunderbird -(Purchased '14)"Muscle Car"
    '88 3.8 V6 EFI Thunderbird -(Purchased '19)
    Columbus, OH
    That happens to be the year the switch was made from 6 bolt to 7 bolt. but as swaps go you're fine. get the VIN of the Donor Vehicle for buying parts from Mitsubishi, the parts lookup program bases everything on that.
    Wichita ks
    That's the only change?
    what about the transmission !
    and I think the head is the same right??
    thanks guys !
    Columbus, OH
    Transmission is ok, just changes to the engine.
    New Bern, NC
    1986 Dodge D-50
    Everything is the same but if it's a 7 bolt you'll have to get a 94 flywheel/flex plate with the 7 bolt instead of 6 bolt.
