Results 1 to 3 of 3
Thread: Homemade Intake
    Dyess AFB, Texas
    1993 Mitsubishi Mighty Max
    Homemade Intake
    Not really sure if this is the right area but here it goes
    found out an adaptor for a 3000GT MAF sensor works to put a cone filter on the mighty max works
    my old box was broken so I spent the $50 to build a new intake
    I think it looks a lot better then the giant stock air box
    los angeles
    looks good man. try to make a heat shield/box it off from the rest of the engine bay so it won't suck in hot air. i'm going to end up doing this sometime in the future. i'm also going to cut a hole in the heat shield and run this piece from the old stock setup into it
    Dyess AFB, Texas
    that's my plan...I have a heat shield from my short ram off my mazdaspeed 3 that I might try to use
