"If anything, the symptoms I get are from getting too much gas, and not from getting not enough". That is what I thought as well, from all the research I did for my weber (any type of hesitation or stumble) is a lack of fuel. I know its unconventional thinking but weber's do not operate like a conventional carb. The primary circuit controls all the fuel from idle to about 2500 rpms then the high side takes over.
