That is exactly correct. 1-4 psi is what they dial in at. I use a mini gauge on mine to check the psi. Though it doesn't have 4x4 moving parts in it, lol. Set it and forget it.
I ordered a P4070 Carter pump and a 12-804 Holly pressure regulator from StreetsideAuto.com- 104.00 bucks and some change.
There is a nut on the reg to adjust the pressure. I may add a mini-guage like Brad has to dial in the correct pressure.
The thing is going to run better than new by the time I'm done.
