Results 1 to 5 of 5
Thread: Mighty Max balance shaft?
    Marion NC
    1996 Mitsubishi Mighty Max
    Please Select Engine Type
    The oil seal behind my pass. side balance shaft sprocket has sprung a leak. I don't have my manual with me today so I'm not sure how to keep that sprocket still while I loosen the bolt. I know you can remove a bolt on the block and use a screw driver on the other side. Anyone know if that's the case on this one? Thanks
    Columbus, OH
    Channel lock on the Belt Sprocket, or IIRC there are some slots you could stick a screwdriver into on the sprocket also.
    Marion NC
    Thanks, just got it off. There is a slight groove worn in the balance shaft. Anyone know where to get a repair sleeve? I've tried all the local auto parts stores. Is it by chance he same part number that is used on the opposite balance shaft?
    Columbus, OH
    Nope, they're different sizes the P/N you want is MD040597
    Balance shaft
    bearing, front
    (pictured on right)
    on this page
    http://www.vfaq.com/mods/balance-shafts.html
    Go Ahead, do the balance shaft delete, then you just have to turn it 180 degrees and loose the shafts!
