Associates Degree
If you drill a hole in the bolt before you heat it up you will have the option of using the easy out if the vise grips slip. Drill the hole with a left handed drill bit and the thing might screw its self out once the heat of drilling it frees it up. Drilling a hole after heating it up might be more difficult if the thing hardens up on you.
