Results 1 to 6 of 6
Thread: 83 Mighty Max clinging to life, need help
Threaded View
  1. #2
    Welcome aboard, I think I can help you here. MCA jet valves can be removed and they sell a kit to fill in the holes that are left when removing them. It is certainly good news that you found the pieces with out finding out later when it could of sucked it into the cam. Sure way to punch a hole in the head if it did.
    The Kit is 4 stainless steel bolts with threaded on the one end that plugs hole and a rubber washer. range from $20-$25
