Results 1 to 5 of 5
Thread: Lug Nuts?
    ORlando Fl
    4G63
    Lug Nuts?
    Hey whats up guys.. SO i have a 1995 Might Max.. Just got it recently.. And i liked the whole EScalade wheel idea.. So i shaved the tabs and the wheels sit flush with the hub, but the issue im having is my from what i know FACTORY lug nuts sink INTO the Wheel!! Its pretty much not safe at all.. If any body knows what type of lug nuts im supposed to use i would really appreciate it!!
    http://postimg.org/image/3o6tfzu81/
    pretty much thats what happens
    Have you tried a tire installation center, those guys would have a good idea what's best and safe for your application. Make sure lugs center your wheel on to the hub or you will get some shimmy up front. 75-80lb torque tighten bolts or will bend your rim if over tight..
    You need buldge acorn nuts 12x1.5 I believe
    Josh
    09 BMW 335i E92 Twin turbo
    Columbus, OH
    Wheel patterns and bolt info for EVERYTHING.
    http://www.roadkillcustoms.com/hot-r...&StudSpreadMM=
    Bulged lug nuts are the answer - the studs on an escalade are 14 mm the trucks are 12 mm - the bulge makes it all line up.
